Choice end position other than the original one?
hello is it possible that at the end of each engraving the laser does not return to its original position but to a chosen position?
thank you
Christophe
Yes you can.
Under ‘Device settings’ you can set whatever position you want, enable the ‘Return to finish position’ slider and set your co-ordinates
thank you I just found, I have more than to test.
