Software and computer are not speaking the same language. If I frame a project on the chuck, the size is off in size. If the project is 2"x2" the rotor rotates and doesn’t stop. Even on a measurement test. What am I missing?
Are you enabling rotary in Lightburn?
Did you follow OLM3 instructions to use rotary? I believe some Ortur machines also have a physical switch to use a rotary, check that please.
