Cleaning the lens on Octo Pro 44W
Are there any instrutions how to cleaning my 44W laser ?
Kristian
Check out the manual here.
We recommend cleaning the lens cover if you do not use the air assist or accidentally do not use the air assist for a project. Debris and smoke can get into the lens cover and the laser will process the glass, causing power loss for the laser. This is especially needed for cutting projects. If your lens is dirty, then it will significantly reduce the power level.
Clean it with a q tip and isopropyl alcohol. Dip the q tip in the alcohol and then twist it on the lens cover. Let dry for 5 minutes before use.
Hope that helps!
That was a good instruction, but
How did I take out the lens
thx James
I found where to clean the lens,
but what does the q tip means ?
cotton swab, American term. Q tip is a brand name of cotton swabs.
