Closed shapes error - SVG
I was going to make a ruler for calibration, but the SVG file gives me a message: 121 shapes were set to scan, but weren’t closed.
These have been removed as they cause problems.
Continue?
I’m not sure how to ‘close’ the shapes - they’re lines.
CMRuler.lbrn (51.0 KB)
I tried to attach the SVG, but computer says no.
It’s because you can’t scan lines. I think what you should do is select all the open shapes, and change them to another layer color and set it to cut only.
Edit menu:
Ah,of course.
I will ‘cut’ at low power.
Thanks.
