: CO₂ laser current drops despite new RECI W4 tube and DY-13 PSU — Ruida signals appear stable
Hello everyone,
I’m looking for help diagnosing intermittent low power on my CO₂ laser. I’m a wood and leather craftsman in Costa Rica.
My equipment:
· Ruida RDC6445G, firmware RDC-V15.01.30.
· New RECI W4 tube.
· New Cloudray DY-13 laser power supply, 230/240 V input.
· S&A CW-5000TG chiller, normally at 22°C.
· Analog 30 mA ammeter in the tube’s cathode return.
· RDWorks. The tests below were performed directly from the Ruida panel.
History
The machine gradually lost cutting power with the previous tube and PSU. I replaced both because of this, but satisfactory cutting was never restored.
Output is sometimes strong initially and then becomes weak. Resting or switching the machine off sometimes improves it, but not consistently. Weak output is also observed directly before mirror 1, so the problem occurs before the mirror path.
Symptoms
With identical settings — 50% minimum/maximum power and a 300 ms timed pulse — I have observed approximately 14 mA with a strong paper burn, and on another occasion 4 mA with no visible mark.
In another pair of tests about one minute apart, the first produced 9 mA and a strong mark; the second produced 5 mA and a faint mark.
Measurements
Using a UNI-T UT191T multimeter:
· L-AN1 to GND: approximately 2.54 V at 50% during 1,000 and 2,000 ms pulses. This remained similar with the laser PSU powered and unpowered while the Ruida stayed on.
· Separate subsequent tests with the PSU powered produced approximately 4 mA during 1,000 and 2,000 ms pulses. These current readings were not taken simultaneously with the L-AN1 measurements.
· L-ON1 to GND: 4.623 V at idle. During a 1,000 ms pulse with the PSU powered, it measured 0.269 V while the tube ammeter indicated 4 mA.
· Ruida 24 V supply: 24.22 V at idle and 24.20 V during a pulse with 4 mA tube current.
· AC measured directly across the DY-13 input terminals: approximately 239.5 V, with no visible change before, during or after a pulse producing 4 mA.
I do not have an oscilloscope, so these readings cannot rule out brief transients.
Cooling water remains around 22°C. Circulation is visible and there are no alarms during normal operation, although actual flow has not been measured. Ambient temperature is about 28–29°C.
Old HV cable and connector
The new PSU has its own attached HV lead, but the inline white connector and the onward cable to the tube include old components. That connector previously rested on the metal chassis floor and left a faint brown mark. I cannot confirm whether this was electrical tracking or simply dirt.
The previous digital current/power display with an adjustment dial was removed because it used an RJ45 connection that the new DY-13 does not have.
Given these results, what would be the most useful next diagnostic step to distinguish a PSU fault, HV cable/connector problem, tube issue or control problem?
I have contacted Cloudray and can provide photos of the wiring and component labels.
Thank you for your help.
Congratulations on doing everything we’d normally recommend. :grin:
We just had an extensive discussion on that:
Let’s see what @eco2laser, a manufacturer’s rep, has to say on the subject.
My bet (as you might expect) would be the power supply, but I’d replace the old HV wiring to eliminate any possibility of an arc / leakage through damaged insulation.
Thank you very much for reading about my problem, Ednisley.
I and other usually refer to this as the laser power supply or lps for short. Since these have multiple supplies, one label generally doesn’t apply to all of them.
The lps has really, only two active control lines. L (or it’s inverted input H) is laser enable and IN which controls the current limiting for the lps. Although there are other lines, these are all inputs, so measuring an input with that device powered down, is kind of frivolous.
The voltage increases out of the lps, until the tube gets to it’s trigger level. No matter where the current goes, it’s what’s controlled. This is why when a tube fails, it opens up and there is no load. When this happens the voltage can get so high it punches through the insulating wire. What you have sounds more like a rubbing or something. Usually the arc leaves a clear mark on the metal it strikes. You have to replace the wire were this occurs as the hole by the high voltage is permanent.
The controller at 50% power will produce about ~2.5V on the analog output and a 50% pwm cycle.
This is likely because you’re running ~12% power, many of these large tubes won’t lase at such low power levels. Even though you’re getting current flow, it’s likely near the threshold to make and continuing to lase. There is a bit of current being used to just start the lase process, usually around your 4ma mark. This can effect your TEM resonance.
You know it’s lasing at 50% power, so the only failure, you assume, is either the lps or the tube. I guess I’m a bit old fashion, but common sense would tell me that after you replaced the lps and tube with new units and that i didn’t fix the issue, then I’d go on the basis of one of these.
  • lps/tube one, or both parts arrived defected.
  • this combination doesn’t fix the issue, need to look elsewhere
  • replacing multiple units increases you chance of failures as you’re adding more unknowns to the circuit.
Trust me, these come from the other side of the planet and there is lots of things that can get shaken and disturbed, failures occur in many places, even when made locally.
From your measurements, it sounds like the controller is working OK. If you burn a hole in the target, it tells you very little. The lowest power and pulse is generally what you want. if it’s in TEM01 mode, it might need higher power applied.
You have some strange issues. I’ve seen a number of people with similar issues, such as it looses power over time. It’s more likely to be the lps, since it’s not cooled except with fans.
If you have these three items…
  1. properly working source (tube)
  2. clean and aligned optics
  3. proper focus
They just work.
Unfortunately, as far as I know, there’s really no good way to tell if it’s the lps or tube. That’s what I was hoping @echo2laser could answer.
You description of it loosing power, sounds more like an lps.
Might want to read the post via the link @ednisley posted, he made some suggestion…
Cloudray has always treated me fair, so I’d trust them to help you out.
You’re not alone here. We see this so often, there’s room in this boat for all of us. :face_with_spiral_eyes:
Keep us up to date. Even though you use RDWorks… lol
:grinning_cat:
Thank you, Jack, for taking the time to read my measurements and explain your reasoning. I especially appreciate your understanding of the cost of replacing parts without confirming the fault.
The key question remains why the tube current changes so much with the same 50% command. Your comments have helped me understand what the measurements tell us and what is still uncertain.
I also checked the cooling flow: collecting 500 ml from the return hose after the tube took 8 seconds, approximately 3.75 L/min.
I’ll keep you updated on Cloudray’s response and any further findings. Thank you for your patience—and for helping an RDWorks user! :grinning_cat:
Hola a todos y gracias por su ayuda.
Comparto los avances de las comprobaciones realizadas los días 19 y 20 de octubre.
Cable de alta tensión y refrigeración
Sustituí el tramo antiguo del cable de alta tensión entre el conector intermedio y el tubo, incluida esa mitad del conector. Se conserva el cable incorporado a la DY-13. La respuesta débil continúa.
El ventilador de la DY-13 funciona. El de la fuente auxiliar de 36 V también arranca al mover el cabezal. El agua estaba alrededor de 22 °C. El caudal medido anteriormente a través del tubo fue aproximadamente de 3,75 L/min.
Configuración del controlador
Leí y guardé una copia de los parámetros de la Ruida, sin modificarlos: tubo de vidrio, 20 kHz, disparo en nivel bajo, atenuación del 0 % y protección de agua activada.
La conexión identificada para regular la potencia es L-AN1 → IN, mediante la salida analógica, no LPWM1.
Mediciones directamente entre IN y G de la fuente
Para dar tiempo al multímetro a estabilizar la lectura, utilicé líneas en movimiento en lugar de pulsos estacionarios breves. La potencia mínima y máxima de cada capa estaban al mismo porcentaje, con una sola pasada.
Prueba Voltaje IN–G Corriente del tubo Resultado
30 %, 100 mm a 50 mm/s 1,519 V estables Aproximadamente 3 mA estables Sin marca visible
40 %, 100 mm a 50 mm/s 2,002 V Aproximadamente 3–4 mA Sin marca visible
40 %, 300 mm a 50 mm/s, unos 6 segundos 1,998 V estables Aproximadamente 3 mA Sin marca visible
Utilicé un multímetro UNI-T UT191T y el miliamperímetro analógico instalado en el retorno del tubo. La lente estaba montada, pero retiré la boquilla porque el centrado del haz a través de ella sigue pendiente.
La orden analógica parece llegar a la fuente con el voltaje esperado mientras la corriente del tubo permanece baja. Sin embargo, hoy no registré una transición de funcionamiento fuerte a débil con ajustes idénticos, por lo que no considero completamente descartado el controlador.
En comprobaciones anteriores medí aproximadamente 239,5 V AC directamente en la entrada de la fuente durante el disparo, alimentación de 24 V estable y señal de disparo L-ON1/TL en nivel bajo.
¿Qué comprobarían a continuación?
Todavía no he pulsado el pequeño botón negro marcado K de mi DY-13. Encontré un manual HY-DY13 que describe una prueba manual, pero menciona un botón rojo y no especifica la corriente de prueba.
¿Alguien dispone de documentación de esta versión que explique si K anula la orden de IN y qué protecciones mantiene activas?
Agradecería orientación para distinguir entre un fallo de la fuente, del tubo o de las conexiones restantes de alta tensión antes de sustituir más piezas.
Muchas gracias nuevamente.
Nacho
Are you running the Ruida off of 24V or 36V?
Many documents for the Ruida machines do not recommend it to run on 36V.
I see your measurements between the Ruida and the lps. I don’t find anything wrong, so I’d look elsewhere.
I and I think the others believe your best shot is an lps. Usually when a tube starts to conduct it uses a low amount of current. It sounds like the lps is the issue.
Unfortunately, the tube/lps combo is difficult to diagnose.
The way an lps works is by current limiting. It lets the voltage increase until the tube starts to conduct. Then you start seeing the current go up. If the tube is open, it’s usually an arc as the voltage goes above the high voltage value and punches through the insulation, usually to chassis.
I’m more suspicious that it’s the lps than the tube. There’s really no good way to measure them
I looked at DY13 lps and most of the ones I saw claim it works with W2 tubes, not w4. I don’t know you have to look for yourself. There is conflicting information about these.
Usually if the K button is the test button, then it just runs the tube at 100% power, ignoring all the input signals. However on mine, the test button doesn’t work unless I unplug the signal lines to the lps.
Good luck.
:grinning_cat:
There are a couple entries that are a problem.
When I entered the basic string in the editor, ‘It lets the voltage increase until the tube starts to conduct.’ the resultant text is ‘It lets the voltage increases the upside tube starts to conduct.’
:grinning_cat:
Gracias, Jack, por revisar las mediciones y seguir ayudándome.
La Ruida recibe 24 V: medí 24,22 V en reposo y 24,20 V durante el disparo. La fuente de 36 V es otra fuente de la máquina; disculpa la confusión.
Cloudray me indicó probar la DY-13 desconectando la bornera de control y usando el botón TEST. Les preguntaré qué corriente debería esperar y cuánto tiempo mantenerlo pulsado.
Además, encontré empalmes retorcidos y cubiertos con cinta en el retorno del cátodo. Voy a reparar ese cableado antes de continuar. Les contaré los resultados. ¡Gracias de nuevo!
Thank you, Jack, for reviewing the measurements and continuing to help me.
The Ruida receives 24 V: I measured 24.22 V at rest and 24.20 V during firing.
The 36 V source is another source of the machine; sorry for the confusion. Cloudray instructed me to test the DY-13 by unplugging the control terminal and using the TEST button. I’ll ask them what current I should expect and how long to hold it down.
Also, I found twisted, tape-covered splices on the cathode return. I’m going to repair that wiring before proceeding. I’ll tell you the results. Thanks again!
It’s pretty conclusive that it’s unlikely it’s the controller.
I was wondering what you use the 36V for in your machine?
If the inputs to the lps are working, I.E. the Ruida, then it’s got to be after the Ruida. Which is only the lps/tube combination.
As someone whose worked in electronics, I’d think the lps would be the most likely considering that the lps works by controlling the current, if this is broken, it might limit it to very low ma, maybe not enough to cause it to lase, but close.
Also, the tube costs multiple times that of an lps for that tube. With the symptoms you have and the costs together, I’d gamble on the lps failing.
Good luck.
:grinning_cat:
Es bastante concluyente que es poco probable que sea el mando. Me preguntaba para qué usas el 36V en tu máquina. Si las entradas del LPS funcionan, es decir, el Ruida, entonces tiene que ser después del Ruida. Que es solo la combinación de LPS/válvula. Como alguien que ha trabajado en electrónica, pensaría que el LPS sería el más probable, teniendo en cuenta que el LPS funciona controlando la corriente; si está roto, podría limitarla a un mA muy bajo, quizá no lo suficiente como para que se desplome, pero casi. Además, la sonda cuesta varias veces más que una lps para esa sonda. Con los síntomas que tienes y los costes juntos, me la *jugaría a que la lps falle. Suerte. :grinning_cat:
Gracias, Jack. La fuente de 36 V es una S-360-36, auxiliar e independiente de la alimentación de la Ruida. Creo que alimenta los controladores de los motores, pero todavía no lo he confirmado siguiendo el cableado.
La Ruida recibe alimentación de la S-120-24: medimos 24,22 V en reposo y 24,20 V durante el disparo.
Gracias por seguir ayudándome a localizar el problema
otro usuario de Reddit comentó que tuvo un problema parecido con una fuente Cloudray y que, en su caso, el potenciómetro de la fuente estaba mal calibrado.
Le pregunté qué modelo tenía y cómo confirmó el fallo; todavía espero su respuesta.
¿Crees que podría estar relacionado con mis síntomas, especialmente que empieza marcando bien y luego pierde fuerza? Gracias de nuevo.
Hola, Jack y a todos. Gracias por seguir ayudándome. Ya cambié el cable de retorno del cátodo e hice la prueba con el botón K/TEST de la Cloudray DY-13.
  • Desde la Ruida: al 50 % y 300 ms, la aguja indicó 5 mA, pero la marca en papel antes del primer espejo varió de razonable a casi nula. Al pasar a 500 ms, el papel se quemó en dos pruebas separadas por 10 minutos: la primera indicó 5 mA y la segunda, 4 mA.
  • Con K/TEST: desconecté la bornera de señal de la DY-13 y dejé el chiller funcionando. Durante el pulso vi unos 3 mA en el miliamperímetro. Se vio la descarga dentro del RECI W4 y el papel se quemó. Adjunto dos vídeos, uno de la aguja y otro del tubo, para que puedan revisar la lectura.
Cloudray me indicó 28–30 mA como referencia para TEST. Lo que observé fue bastante menos, incluso sin la señal de la Ruida. Como el disparo fue breve, no sé si la aguja llegó a estabilizarse.
¿Cómo interpretan ese resultado? ¿Qué comprobarían a continuación para distinguir entre la fuente, el tubo y sus conexiones?
Gracias de nuevo,
Nacho
Hi Jack and everyone. Thanks for continuing to help me. I’ve already changed the cathode return wire and tested with the K/TEST button on the Cloudray DY-13.
From the Ruida: at 50% and 300 ms, the needle indicated 5 mA, but the mark on paper before the first mirror varied from reasonable to almost none. When moving to 500 ms, the paper was burned in two tests separated by 10 minutes: the first indicated 5 mA and the second, 4 mA.
With K/TEST: I disconnected the signal terminal of the DY-13 and left the chiller working. During the pulse I saw about 3 mA in the milliammeter. The discharge was seen inside the RECI W4 and the paper was burned. I am attaching two videos, one of the needle and one of the tube, so you can review the reading.
Cloudray gave me 28–30 mA as a reference for TEST. What I observed was significantly less, even without the Ruida’s signal. Since the shot was brief, I don’t know if the needle stabilized.
How do you interpret that result? What would you check next to distinguish between the source, the tube and its connections?
Thanks again,
Nacho
If you use the test button on the lps, mine lases 100% with the signal cable removed.
It’s better to help debug things without using 100% power. This usually ends up in disaster. So use the console where you can set the pulse length. I use manual, which stays on, but only at 50% power.
With the test button I’d expect full current, such as what Cloudray advised, not 5ma. You should not see a variance while it’s lasing, since you’re asking for a 50% pulse as long as you hold it down.
It doesn’t sound like the lps is actually working correctly.
Since these are replacements, I’d advise asking Cloudray again. Sometimes it takes a while. They do have a site, but it’s usually 24 hour turn around time. Since they are sleeping when you email them.
I’d question the lps, but this is a problem area as there is really no good test to confirm if it’s the lps or the tube.
:grinning_cat:
Muchas gracias, sigo en la lucha
