Co2 Galvo laser burned size larger than design
Any one can help me? I have a co2 galvo laser. There were no problems to engrave with ezcad2 software. Then I purchased latest Lightburn, imported the file markcfg7 to set up, and I found that the burned size is larger than that of design.
I tried a 100x100 mm square, and got 117x117 mm on the wood sheet.
Here is a screenshot of the basic device settings:
and the console input is grayed out so that I can’t type any commands like $, $$ (learned online)
Sorry, I’m a newbie. Your help is highly appreciated.
9
Commands input field is grayed out.
There is no “machine settings” in Edit as well. Only “Settings” and “Device Settings”.
In the imported message, it says “Field Size: -1.32327e+25 mm”
What does that mean? What is the exact field size? Thanks for your help.
click here to adjust scale from your measurements
Thank you, fins. The problem was solved before I saw your reply.
But I don’t know why. I just clicked the “clear” button and reload COR file from ezcad2 folder. It works!
Thank you again.
