I see a lot of beginners here asking which laser tube to buy, so I wanted to put together what I’ve learned from working with CO2 tubes for years.
1. Length matters more than you think. Your tube length determines the cavity size and output stability. Measure the old tube before ordering — a tube that’s too long won’t fit, and one too short may not reach full power.
2. Rated power ≠ actual cutting power. A 60W tube realistically cuts like 50W after optics and beam losses. Always ask for the actual working current range, not just the label power.
3. Lifespan depends on how you run it. Three things kill CO2 tubes early: running above the rated current, poor water cooling (keep water under 25°C), and frequent full-power starts. Run at 60–80% of rated current and a tube can easily last 8,000–10,000 hours.
4. Signs it’s time to replace: noticeably weaker cuts, the beam spot getting larger, or discoloration near the discharge end.
5. What to check before ordering: tube diameter, length, discharge length, connector type (HV/GND), and whether your power supply matches the tube’s working voltage.
A detailed comparison table (dimensions, working current, matching PSU) is available here: CO2 Laser Tube Power Matching - ECO2 Laser |High-Performance Industrial CO2 Laser Tubes | Hengkuai Laser
Happy to answer questions in the thread — if you’re unsure what tube your machine needs, post your machine model and current tube specs below.
