Hi everyone,
I’m hoping someone with experience in CO2 laser tubes and high-voltage systems can help me understand what’s happening here.
I have a Chinese-built CO2 laser machine with the following setup:
Laser tube: 100W CO2, manufactured in 2017
Operating hours: Approximately 130 hours, tube looks almost new, with no visible signs of overheating or burned brass bushings.
Laser power supply: HY-W120-R
Controller: Ruida RDC6332G
Chiller: S&A CW-5000
Coolant: Fresh demineralised water, system thoroughly flushed
The machine gets imported by a reputable brand in my country. (They modify the safety system)
Mechanically, the machine looks fairly new and appears to have been properly maintained and cared for. I usually cut at 65% power. (Acrylic)
The problem:
The original issue was that the laser would occasionally stop firing during both engraving and cutting, while the machine itself continued operating.
This would happen after using the machine for about 10 minutes. (so might be temperature related)
While investigating this, I noticed intermittent internal electrical arcing near the positive (high-voltage) end of the laser tube.
The discharge appears to jump from the positive electrode area towards the mirror assembly, underneath or near the ceramic housing.
I’ve attached videos showing the behaviour.
What puzzles me is the apparent current path.
Somehow, the high voltage seems to find a path towards the mirror assembly rather than following the intended discharge path through the gas.
Interestingly, the normal gas discharge appears to continue simultaneously. (This has been different, where there would be 0 output at all)
If this is genuine arcing to the mirror assembly, how does the current complete its circuit back to the power supply?
There is no visible arcing at the opposite (negative electrode) end of the tube.
One possibility I’ve been considering is that the current somehow finds a path through the cooling water, into the chiller, and potentially through protective earth back towards the power supply.
The cooling circuit contains fresh demineralised water and has been thoroughly flushed.
I’m also wondering whether an internal insulation failure, contamination, or deterioration of the tube could cause this.
The tube dates from 2017 but has only 130 operating hours according to the Ruida controller.
Given the condition of the tube and the overall machine, I believe this reading is plausible.
I realise that calendar age matters for sealed CO2 tubes, regardless of operating hours.
I haven’t yet established whether the laser’s optical output has deteriorated, as I don’t have the equipment to measure it.
What concerns me most is the possibility that the internal arcing has damaged the mirror assembly or its reflective coating.
As far as I know, the mirror/cooling assembly on these sealed glass tubes isn’t realistically repairable. Is that correct?
I’ve already ordered a replacement laser power supply, as I initially suspected the existing HY-W120-R might be contributing to the problem.
However, I’m now questioning whether the power supply is actually responsible, or whether the tube itself has developed an internal fault.
I don’t want to risk damaging the replacement supply or causing further damage to the tube.
For now, I’ve stopped operating the laser until I better understand the issue.
My questions
Has anyone seen internal arcing towards the mirror assembly at the positive end of a glass CO2 laser tube?
Could this indicate a failing tube, or could an abnormal high-voltage supply cause this behaviour?
How could the electrical circuit be completed if the discharge really is jumping towards the mirror assembly?
Given the tube’s age (2017) and relatively low operating hours (130), would you suspect deterioration of the tube itself?
Please take a look at the attached videos, as they show the discharge much better than I can describe it. I have made videos from the laser engraving aswell as cutting. The metal tab doesn’t seem broken/disconnected from the brass bushing.
Any insights from people familiar with glass CO2 tubes, their internal electrode construction, and high-voltage failure modes would be greatly appreciated.
I’m honestly running out of ideas here, any help/tips are welcome.
English isn’t my first language, so I used AI to help translate and polish this post.
Thanks in advance!
