Coatings for ceramic tile engraving
Hello all,
I know this is an old topic and feels like beating a dead horse but after searching I couldn’t find anything related to my question about the various coatings people use prior to engraving.
The spray paint options work but I don’t like the messy cleanup with solvent. The fumes are bad and lacquer thinner is $25/gal.
I prefer the TiO2 DIY mixture which is water cleanup, and have tried many variations.
Here’s my question: Back to the Rustoleum options. I tried the Cold Galvanizing Compound and it works well. You get a different finished texture on the tile vs Rusto Heirloom White. The specs on the Cold Galvanizing Compound showed that it contained zinc dioxide. Just for curiosity I tried a DIY mix with ZnO2 powder instead of the TiO2 powder and it did not work.
Since both TiO2 and ZnO2 are used in sunscreen recipes I figured they both have light absorbing properties, but as my friend Pedro says, “me no know”.
Has anyone ever had luck using zinc powder instead of titanium dioxide? There is a difference in the finished texture as mentioned above using the Rusto products which may be a desirable outcome
I would wonder about any adverse reactions from zapping zinc powder. It’s a bad idea to be welding zinc plating (galvanized steel) and I’m sure the powder version will vaporize even easier.
At the very least, heavy ventilation outside, but most people don’t keep the laser out of doors.
Another option is acrylic paint in a spray can. I have had some luck with it (white) and it is water cleanup.
With regard to the TiO2 mix, would you be willing to share which formula worked the best for you? I’ve just obtained some of the powder and some ceramic tiles, and I’ll be running a test program soon.
Ah, I just use rustoleum gloss white and I don’t remove the paint afterwards, but I’m extremely lazy.
I’ve used this one with good success… there are a bunch of diy mixtures out there.
It’s a pretty long thread, but it may, in the end, save a lot of work.
Good luck … we expect you to post some of your photos. :wink:
:grinning_cat:
Glad to share my recipe.
I buy the TiO2 on Amazon, and the Essential Labs seems to work well. This one has a fine granulation and that helps when mixing to minimize lumps.
I go by weight, using a small gram scale, also purchased on Amazon. I try to get an end result with 20% - 25% TiO2 in the total mix. More Ti makes it harder to mix, and it clogs up the sprayer.
I use an HVLP touchup sprayer from Harbor Freight (https://www.harborfreight.com/120cc-hvlp-touch-up-air-spray-gun-61473.html) because everything I tried with a brush or sponge or roller left streaks and inconsistent results.
I use some tempera paint to add some color so I can see the coating on the white tile and also help keep the TiO2 in suspension. It precipitates out readily as it is not soluble in anything except HOT sulfuric acid. Some folks use PVA glue as opposed to the tempera. I’ve tried it but not enough to get consistent results and I don’t think my sprayer nozzle likes the PVA.
My latest batch is as follows:
TiO2
Oops, posted before I finished, must have fat fingered the wrong key.
TiO2 - 30 g
Tempera - 25 g
Water - 75 g
This batch amount makes enough to spray more tiles than I need for any one occasion. I keep it in a jar in the shop fridge and give it a good stir prior to each use and it can last one or two months no problem with great results.
I use a little coffee frother to mix and it works well but tends to aerate the mixture (adds lots of bubbles) so I let it sit for a bit then mix again with a small stir stick and proceed to spray on my prepared tiles.
Thanks, everyone. I’ll post up how it goes.
