This may be complicated or I am doing this in a complicated way. I asked Chat GPT to generate some animals. When I trace them in LB, I get two lines, in which LB will burn both side by side.
Does LB have a function to generate a singe vector line instead of two adjacent lines on an image trace? Zoom in on my trace please. Or should I import into illustrator for this?
I needed to combine this image with another shape, show in the file. I needed to cut out the left side of the cat with the rest of the polygon while the right side is engraved as a line. I had to use the edit nodes too to break everything apart, assign a cut (red line) and patch them back together. Is there a better way to do this? Like, can you trace one side of a complicated object or assign one side to a different layer. Please zoom in on the cat and see my tow hour long handiwork?
From what I see in your small (upper) version, you want to have an extended cutout of the rectangle with a cat engraved on it. Unfortunately, there is no shortcut other than using the Nodes Break and the Trim Tool suggested by @JimNM to snip off the unwanted parts.
If I got it right, then you were just a couple of steps from being done. I did a path Join on the red lines (Fill mode shows it is a closed path), and removed the offset from the Red cut. Revised file attached. Check it out in Preview.
