I have two material libraries I thought that it would be easier to use two but have decided that I only want one is there an easier way than hand copying all the settings and entering them into to the other.
I don’t know of an easy way to transfer settings from one library to another.
It probably wouldn’t be too hard to open the files in a text editor and merge the contents of one into the other. You’d just need to be careful to place the contents into the right location.
If you try this, please take a backup of your cut library files just in case you corrupt them.
Wow! That did it. Thank you I had not thought about that.
