Hi all. I have an issue with my 22w Falcon 2. Connected rotary drive 2 weeks ago, played a bit and removed again. Didnt use machine till this weekend. Not homing and in machine settings it shows “communication with controller failed”. Any suggestions? Thanks
Maybe you disabled Home cycle for rotary operation.
Check your coms port and if you have pressed the red switch.
David,
Be sure to reset the rotary function switch in Lightburn just in case it still thinks you have the rotary unit still attached.
Hi. Did check what you suggested, but still having the same problem. Also, the x-axis slowly creeps to the right and motor gets bloody hot. I did upgrade to newest version of Lightburn but went back to older version.
