Configuração para corte acrílico (Setup for acrylic cutting)
Há alguma configuração diferente no lighburn do corte no mdf para corte no acrílico a minha laser two tree ts55 tem a informação que corta laser, mas não consegui.
There is some different configuration in the lightburn from the cut in the mdf to the cut in the acrylic my laser two tree ts55 has the information that it cuts laser, but I couldn’t.
correção: “a minha laser two tree ts55 tem a informação que corta acrílico, mas não consegui.”
correction: “my laser two tree ts55 has the information that cuts acrylic, but I couldn’t.
If the laser light passes through the acrylic, it does not cut.
If the acrylic is white or silver, it can be reflective.
If it reflects the light, it does not cut.
Aside from this knowledge, engraving slower and adding air-assist are the next ideas worth testing.
The larger CO2 lasers can cut clear acrylic and other visually clear plastics because the infrared light is absorbed by the plastic.
You are welcome to show pictures of your results. Perhaps there is more advice to come.
