Is there any way to configure lines per mm in LB?
‘Line Interval’ can be found in the ‘Cut Settings Editor’ window. Double-click the layer to expose this:
You can also set from the ‘Cuts’ window.
Thank you very much!
If this solved the issue for you, please mark as such to help others find this response easier. Thanks
