Can I use lightburn to engrave the above mentioned shaped tumblers, is even possible in general if not with lightburn? Would you edit the shape, pattern, text dimensions to account for the increased circumference?
Here is a picture of dims, any help is much appreciated TY.
Tip one end of the rotary up so you get the working surface parallel with the laser travel so it’s in focus as much as possible along the length.
For a gradual taper like that I usually just measure the diameter where the center of the logo would be and use that and don’t try to edit the pattern to fit.
