I am trying to connect via Comm port 10. Was workng fine withd version 1.4. Now with Version 2.1 does not work. IT does does not go Home and you can not reset the X axis. On power us, sometime it words. Then it fails. Can get not work reliably Under the console I get the message, “cant connect” or I getm"[MSG: DC power low, please input power.]
NOTE:?
parsec
(FerAS)
September 10, 2026, 10:16pm
3
Maybe try another power supply, better with a bit more amperage.
MikeyH
(Mike Hembrey)
September 11, 2026, 12:21am
4
You are lucky. A lot of people with power supply issues do not get this message.
I got a 12V and a 24 v system
I measure 24.3V DC at the connector. I will get a new P/S over the week end
MikeyH
(Mike Hembrey)
September 11, 2026, 5:35pm
7
It is possible for the supply to read properly with no load (just a meter), but the output to drop under load.
I gto new ps. It meauses 24.7 now.
Stillsame problem
MikeyH
(Mike Hembrey)
September 12, 2026, 7:07pm
9
If it is still getting the low power message, then it is a connector or wiring issue.
daniel.brisson247:
Stillsame problem
You did not say which problem. You listed two of them.
i gt it to work by bypassing G-Lightburn and go direcly to laserGRBL. disonnect and reconnect then Disconect. Heading to lifghtburn work after that
MikeyH
(Mike Hembrey)
September 12, 2026, 9:47pm
11
Is it possible you originally had LaserGRBL still open when Launching Lightburn? They cannot control the COM port at the same time.
I downgraded to 1.7. That worls well.. Scale and comm 10 working good againg.
