Hi all,
Does anyone know if i can extend the bed area of my Eleksmaker by using longer extruded aluminium supports? If so, is there a specific name for it and is there a good supplier?
Your probably looking for V-slot linear rails. A good source to check is: https://openbuildspartstore.com
The rails are 40 x 20 and 20 x 20 V slot rails. In the UK I got mine from Ooznest.com, but they are readily available. you will obviously need belts as well and I got mine from Amazon
Hope that helps
David
Thanks guys for the pointers will check them out.
