Grbl 1.1h LB 0.9.018 Windows 10 Pro 2004 64bit
I have turned on $J jogging and continuous jog.
When I hold down the Y axis buttons, both + and -, the machine moves until I release the button. When I hold one of the buttons down again, it does the same thing again. Perfect.
When I hold down X axis right/+ button, the machine moves until I release the button. When I hold the right/+ button down again, again it moves the same way. Perfect again.
However, when I hold down the X axis left/- button, the machine moves until I release the button. But, if the hold the button down a second time, nothing happens.
If I then move the Y axis, I can again move the X in the negative direction.
If I turn off continuous jog, the machine behaves as it should, one jog for each press, even when it will not move in continuous jog mode.
I don’t know if I had the same issue with version 0.9.016. I never installed 0.9.017.
This is not a big deal but if there is something I can do to fix it, it would be good.
Tks.
