Control Z and U Axis
Hi,
We are looking to send Z and U axis coordinates to our machine through Lightburn, we aren’t worried about moving these during firing, simply before a part is loaded and then it will stay in that position until all those products are finished and we move onto a different shaped item.
We are using a Ruida 6442 controller, but we aren’t able to use the console on Lightburn, we can use saved positions but this only allows for XYZ and not U, we can jog all 4 axis manually in the “Move” tab which would assume what we are trying to achieve is possible, but we want to be able to define a coordinate so each part is set up exactly the same each time.
Any help on this would be massively apprecated!
Thanks,
Jamie.
