Hello,
i am having 2 machines and do really love the software but issue up here with me is both the machine even though having ruida controller have different home origin position, due to which i have to change settings for each project, depending on machine on be usedand many a time mistake happens
Can we save different machine settings and when we select machine,setting changes.?
Currently also using rdworks as alternative
Even if using the same controller type, it’s expected for you to have separate machine profiles unless the 2 machines in question are identical in their setup. So just setup another profile so that each have the correct setting for their specific machine - then the settings with automatically change when you choose each profile.
