# Converting Foot Switch from Input to OUTPUT
**URL:** <https://forum.lightburnsoftware.com/t/converting-foot-switch-from-input-to-output/160191>\
**Category:** Galvo\
**Tags:** windows11, galvo, windows\
**Created:** [December 20, 2024, 7:15pm UTC](https://forum.lightburnsoftware.com/t/converting-foot-switch-from-input-to-output/160191 "2024-12-20T19:15:15Z")\
**Showing post:** 12
**Author:** ![Data77](https://forum.lightburnsoftware.com/letter_avatar_proxy/v4/letter/d/fbc32d/32.png) [@Data77](https://forum.lightburnsoftware.com/u/Data77)\
**Post date:** [December 25, 2024, 2:06pm UTC](https://forum.lightburnsoftware.com/t/converting-foot-switch-from-input-to-output/160191/12 "2024-12-25T14:06:02Z")
I have a Monport GA100. I want to add a Safety Door Switch.
Options:
1 Add a logic circuit as described above - Need to know the port on the BSL Control Board
Also, need to know how to get inside the unit
2 Put a switch on the 48V Laser Supply - Need to know which screws to open the case
3 Attach to the 2 port located on the back. I don’t know which port it is assign to.
Lightburn Door Switch does not match this port in the LB settings
As you see, there is not easy options. But this thread has helped me get on the right path. The typical diagram is a big help to start.
Thanks for any input and discussion.
_[View the full topic](https://forum.lightburnsoftware.com/t/converting-foot-switch-from-input-to-output/160191)._
