Cookie cut multiple objects
Hello,
I am trying to do a simple task to me but can’t get it to work.
I have my object here group or not grouped and I am trying to keep only objects within the circle so I can engrave on a coaster.
Is it possible to cookie cut with lightburn. I can’t select the Boolean tool.
Thanks
  1. Make sure the cut shape is on the top most layer.
  2. Select all shapes you want to cut as well as the cut shape
  3. Tools->Cut Shape
  4. This should leave you with the discard pieces selected. Push Delete key to remove or simply relocate
Hello,
Thanks… but cut shapes is always greyed out.
Can you attach the .lbrn file here for review?
Forum.lbrn (895.1 KB)
Here it is. Thanks
perfect, thank you
