The scaling option in “Copy Along Path” is much appreciated!
Unfortunately I think there is a minor issue with it.
When you switch to “Space Between Copies” mode, scaling is disabled which is fine. However, if you leave scaling toggled on when switching to “Space Between Copies”, the result is different to if it is toggled off before switching. If left toggled on, the scaling begins to affect all of the created objects equally rather than incrementally.
Thanks in advance,
James (an otherwise very happy user)
