Copy/paste fill
copy to clip board a fill text in one LB image into a blank one and the fill becomes a line. why?
Please consider posting a photo of the problem to help explain your issue.
My first thought is that you have duplicated shapes sitting directly on top of each other, which will make those shapes (set to fill mode) look like they are set to line mode. But I am wrong at least twice a day…
Thanks, checked that but only 1 object.
Did I upload a pic. properly?
This is because layer information is not copied. A new LB file will revert to default layer settings and therefore set the new layer to line. You either need to set a different standard for that layer or live with it (it’s usually a good idea not to copy settings between graphical objects).
thanks that’s it.
