I was wondering there is any thought of Corel Draw file support like Rd works?
RDWorks doesn’t import CorelDraw files, it uses a Corel macro to send files to RDWorks, and LightBurn does the same.
Thanks, that what I meant anyways…
There is one thing needed that’s not currently in the document - when you install the corel macro file, you need to copy it out of the LightBurn program folder and put the copy into Corel’s global macro folder, and use it from there. If you don’t, it’ll work for a run, but when you re-open Corel it won’t be there.
