Is it possible to export a selection from CorelDraw and have it import into an existing Lightburn session instead of opening a new file
If you are asking if you can import an SVG file into an existing open project, in order to merge the two, the answer is yes. I just did it.
It is up to you to experiment with other possible combinations. ![]()
Are you suggesting that you used a macro in Coreldraw to import into an open Lightburn session?
No, the file was already saved. I used the Lightburn Import function. It was also an SVG, not a Corel file (which I can’t create).
