I did a lot of editing to this file. I have narrowed it down to this layer, and when I try and burn it lightburn stops responding and can’t save gcode. Anyone have any ideas what happened? I will probably have to reedit this whole layer again.
corrupted.lbrn2 (375.3 KB)
I am away from home but it seemed to run fine in Preview. I slowed it down so I could see if there was anything quirky.
T H E N . . .
I tried saving the GCode and that went south. Then I tried converting it to a bitmap, and that failed as well. I tried to save the blue layer (circle) as GCode, and that worked. I tried to save the red layer (tree) as GCode and another fail.
At this point I am wondering if this is a part of a purchased file. ![]()
Last idea, I Export it as SVG, close Lightburn, then Import it back in. Joy!
I have no idea what was up with that file, but here is something I think you can use.
Tree of Life Layer.lbrn2 (282.2 KB)
Maybe the LB Developers can figure out what was going on in that file.
Huh, You saved me from having me stump the tree again, thanks.
It was as I remember a free tree of life in an svg format, single layer and I am trying to make it into a 2 layered file. All worked till I got to this layer.
I keep hoping somebody will post one of those 4-5 layer ones. ![]()
In your layer sequence, make sure your final cutout is the last layer. I was a bit confused about what got cut out and what remained.
Here’s the best I got so far, technically 3 layers. It’s still got the corrupted layer.
layered tree of life.lbrn2 (1.4 MB)
I am working on the original. Two versions, tree falls out and tree remains part of the board. The second one is the tough one. ![]()
Will post when I get it done.
Tomorrow. I am making too many mistakes. ![]()
I made a clock/template and was looking for things to put in the middle.
So far the tree of life and a Yin and yang. It least that ones easy. I’m finding tree of life is to intricate and the first one caught fire, so I trimmed some leaves and fattened up branches. May just end up with single layer.
Speed it up and make multiple passes. Air assist on. I left the settings in the file close to yours.
I cut 3mm ply with 40w at 2600mm/m, 95%, constant power, air assist, and 6 passes (5 is enough most of the time). My 20w cuts the same, except at 1800mm/m.
The attached file has the tree in both versions, falls out and retained. You should be able to replace your bad layer in the layered tree of life file with the falls out one. You mentioned clocks, so I added a 1" ring to the retained one with a 7mm hole. Feel free to adjust as you see fit. Just so you know, I usually make my clocks about 10" in diameter. If you resize it, don’t forget to fix the center hole.
Tree of Life LayerFix.lbrn2 (519.6 KB)
Those cut settings where probably random because I used the one from art library. I wish it would retain your settings.
I thought about using defaults, but gave it up. Now I just check everything out of habit. I am not doing production work, so it is not that irritating.
