Do i need to plug the k40 power supply to the cohesion board if I have the power module?
If the Cohesion Board is powered from another source, then the only connections you need from the Cohesion Board and the Laser Power supply is the Beam On signal and return.
You will get the most accurate setup and configuration information using the wonderful resources provided by the nice folks that produce this Cohesion3D control system.
