I have a Longer B1 diode laser and upgraded it with the extensionkit so it is now 800 x 400 cm.
I want to change the layout of my workspace, because now it is going upwards, 400 wide & 800 high. I want it from left to right, so 400 high and 800 wide. I changed the settings in “machine settings” in LB, but now I need to change the settings in “Console”. The $ code for 130 and 131. How can I make the console visible with the $ codes? Now it is an empty space.
There are two ways:
1 - Through the “Console” window, type $131=400 (or 800 as appropriate) and press enter. (You should then see the message “ok” if you did this successfully).
2 - Through the “Machine settings” window, you can edit the desired value directly in the $131 field then “write” and “ok”
