I’m not sure if I’m breaking the rules here… If so please remove.
I need to procure someone’s help in making a small tealight stand. The stand would need to be able to hold a 13cm diameter mirror (very light) resting on its side so that a tealight could them shine through the mirror from behind.
I believe 3mm ply would be suitable…
The mirror effect I am after is as below but without the need to hold the mirror in front of a lamp!
Ideally I would like a decent supply of these and would happily pay for them obviously… Say 10 - 20 to start.
oops,I thought is was still on the CNC router forum.
Sorry about that.
I have a diode laser also, and no it will not cut.
Yeah, you need to find someone with a C02 laser.
FYI, you can buy battery powered LED “tea candles” off of Amazon that mimic the flickering of a candle pretty well but don’t have the danger of an open flame. They are great for lowering legal liabilities if you are selling or giving your items to others. These are pretty cheap if you buy in bulk.
I know tea candles are approximately 38mm /1.5" in diameter, and the mirror is 13cm so that part is noted.
But what is the thickness of the mirror plate?
Sorry about that fellas, I linked the wrong thing obviously. I remove the OP link and here is the correct one I intended to provide the first go round> TeaLight Stand (3mm Ply)
