I did a job with multiple repeated patterns on and multiple passes for different layers, when it went back to do the next layers it’s all misaligned. Could this be the cable? Or could it be the belt? I did adjust the belt and runners, could I have done them both too tight?
Possibilities:
Belt, acceleration / skipping steps, velocity
Try slowing things down and see if you have the same issue.
I’m going to loosen the runner wheels to see if that helps, I think I may have done them too tight. Will also check backlash
