CR Laser Falcon 10W turns goes to the corner, but when it returns to the middle is stuck
Working with a CR Laser Falcon 10W. I have had multiple successful cuts. Randomly, the machine started jamming at start up. When I turn it on, it beeps three times, goes to the corner and returns to the center. Instead of beginning the process of outlining the workspace, the laser is stuck in the middle vibrating.
Sounds like hardware related
Try this
a) set the power to somthing very low like 1%
same behaviour?
b) confirm your axis are square to the frame and all belts and wiring are nice and not being tugged
c) confirm the power adapter does not fade its little LED when machine starts (could indicate failing or faulty power adapter)
Post a video of the original homing from cente,r that might give some visual and auditory cues as well
