Hi,
I’m using LightBurn 1.2.01, and seeing consistent crash when attempting to rubber-band frame a 2x2 virtual array. I have no issue when using cut boundary frame method. I also noticed that the program crashes if I add the array, then try to save the file. I tried this on two different files.
Here’s the Crash_Log
Crash Log Stack Trace:
PathWalker::GetPoint
TextShape::BuildTextAlongPath
TextShape::BuildPath
TextShape::GetPath
Shape::FlattenToPath
Shape::Flatten
Shape::Flatten
ConvexHull::AddVerts
MainWindow::on_pbOFrame_clicked
MainWindow::qt_metacall
QMetaObject::activate
<couldn’t map PC to fn name>
<couldn’t map PC to fn name>Undo Stack:
Create Array
Select objects
Clear selection
Change cut settings
Set cut type
Set cut type
Select objects
Select object
Clear selection
Select object
Remove Array Shapes
Set cut output flag
Set cut output flag
Set cut output flag
Create Array
Remove Array Shapes
Create Array
Select objects
Select object
Clear selection
Select objectsRedo Stack:
msinfo32.txt (875.9 KB)
