Crashing after updating overlay
When I open lightburn, it will connect to the laser and camera like it should, and update the overlay as it should. Shortly there after, however, you will notice the image in the camera area will freeze, and if you try to update the overlay or find the laser again by right clicking"devices" in the lower right, it crashes. running macOS ventura
Please check to make sure LightBurn is allowed to access your camera in your Mac’s ‘Security & Privacy’ settings.
System Preferences > Security & Privacy > Privacy > Camera > make sure the box next to LightBurn is checked.
If that doesn’t work, check to see if your camera is working with another app, like Photobooth. Make sure you are directly connected from your camera to your Mac, without any USB hubs or extenders (if you need to use these, they must be externally powered).
