Crash Log Stack Trace for LightBurn v1.3.01:
QAction::setEnabled
CameraControlWidget::ReleaseCamera
CameraControlWidget::~CameraControlWidget
CameraControlWidget::`vector deleting destructor’
QObjectPrivate::deleteChildren
QWidget::~QWidget
<couldn’t map PC to fn name>
is_exception_typeof
_C_specific_handler
is_exception_typeof
_CxxFrameHandler3
_GSHandlerCheck_EH
_chkstk
RtlUnwindEx
_C_specific_handler
_chkstk
Undo Stack:
Edit Vertices
Select object
Delete selection
Select object
Break Shape
Edit Vertices
Edit Vertices
Select object
Break Shape
Break path
Insert shape vertex
Select object
Edit Vertices
Edit Vertices
Edit Vertices
Edit Vertices
Edit Vertices
Edit Vertices
Ungroup shapes
Select object
Delete selection
Select object
Clear selection
Paste selection
Select object
Clear selection
Scale Selection
Move selection
Scale Selection
Select object
Move selection
Select object
Clear selection
Scale Selection
Move selection
Create Ellipse
Clear selection
Set cut hide flag
Select object
Clear selection
Select object
Move selection
Select object
Clear selection
Ungroup shapes
Select object
Move selection
Select object
Clear selection
Ungroup shapes
Select object
Clear selection
Scale Selection
Move selection
Select object
Clear selection
Ungroup shapes
Select object
Move selection
Move selection
Select object
Move selection
Select object
Clear selection
Group shapes
Select objects
Clear selection
Select object
Move selection
Select objects
Select object
Move selection
Move selection
Select object
Clear selection
Move selection
Select objects
Clear selection
Move selection
Scale Selection
Select object
Clear selection
Move selection
Select objects
Clear selection
Move selection
Select object
Clear selection
Move selection
Move selection
Move selection
Move selection
Select objects
Clear selection
Select object
Move selection
Move selection
Edit Text
Edit Text
Edit Text
Edit Text
Edit Text
Edit Text
Select object
Clear selection
Set text font
Select object
Select object
Select object
Move selection
Scale Selection
Move selection
Select object
Clear selection
Move selection
Move selection
Move selection
Move selection
Select objects
Move selection
Set text spacing
Set text font
Select object
Clear selection
Select object
Clear selection
Move selection
Select objects
Clear selection
Move selection
Move selection
Move selection
Select object
Clear selection
Scale Selection
Select object
Move selection
Scale Selection
Move selection
Select object
Delete selection
Select object
Clear selection
Move selection
Select object
Redo Stack:
Support Data:
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
