I set up the Creality Rotary pro with my Creality Falcon2 Pro and everything seems correct when doing test and framing, but when I try to engrave the rotary will not rotate. Any Ideas as to what I’m doing wrong?
Lots of ideas, but we need lots of more information. For starters:
- Rotary not plugged into the controller board.
- Cable to the rotary is not wired properly. If there was a short patch cable, try that.
- Wrong axis selected in the Rotary Setup window.
I am totally guessing because you did not tell us if the Yaxis was moving or the rotary moved when you hit the test button. You also did not mention whether or not there were any error messages.
Do some testing, answer some questions, and we can go from there. The rotary is really not very complicated.
