Create a serie of decreasing shapes
Hello, I would like to create 30 instances of a shape with a decreasing size (I define the first and last one, all the intermediate should be generated) . Is it possible to automatise this or do I ahve to do it manually? Tanks for any help.
An easy way is to reduce the copy of nr1 with the LB percentage function, then nr2 with the next reduction in % and so on. It is not fully automatic but takes 95% of the otherwise manual work.
thank you bern.dk for that. It’s not exactly what I hoped, but it will make the job.
I currently don’t see a better way to automate this further than what Bernd suggested.
What you’re asking doesn’t sound too complicated to implement. :slight_smile:
(It could be added as an option in Grid Array)
We welcome suggestions on new features at https://lightburn.fider.io/ - we’d suggest you make a post there detailing the feature you wish to see, and describe your specific use case.
We closely monitor these, to help us choose which features are most important for us to develop next.
