I have messed up a few jobs due to forgetting to check the cut settings when going from wood, to foam board, to card stock.
Would be nice if there was a way to save settings profiles for each material type.
This way you could select a material profile, and your pre-established cut settings would load.
this function already exists in the software.
we use it all the time to load pre-tested settings for different materials and thicknesses.
The Material Library is the way of doing this.
I’ve been using the material library too. I only wish it would auto save. I added custom settings several times and lost them because I didn’t manually save them.
Thank you,
I will have a look at it.
