Create Path Segment
Is there a way to create a path segment so that I can re-cut only a small portion of a much larger path?
In illustrator I would use the direct selection tool and then delete the points that I don’t want anymore. Does Lightburn have a tool like this?
I would use boolean operations, but they all re-close the path.
Check out Tools->Cut Shapes.
Cut Shapes Tool - LightBurn Software Documentation
That works. Thanks!
