Creating a Template in Lightburn
Is it possible to create a template in Lightburn? I have created several files that I use repeatedly in Lightburn and every once in awhile I screw up and make a change to the “master” file. I am wondering if it is possible to create a template file that I can bring in to Lightburn and work with it, but not be able to accidently save it and overwrite my original “master”. In other programs such as Word I can create a template that I can work with, but the program requires that I rename the file before I can save it thus protecting the original from accidental overwrite. Is there such a feature in Lightburn? Thanks for your help.
Save your item in the ART LIBRARY.
I save mine in a templates directory an just import it.
:grinning_cat:
I never thought of that. Great idea. Thank you.
LightBurn 2.1, which is in Release Candidate stage now has templates in it. You can save a file as a template document, and when you open it, any changes are forced to be saved to a new LightBurn document so you don’t overwrite your template file.
https://docs.lightburnsoftware.com/2.1/Reference/FileManagement/#save-as-template
