Critical Bug: Geometry shifts and scales automatically during fiber laser runs
We are experiencing a severe issue where geometry is automatically altering itself during active jobs on our fiber laser. Specifically, the software will randomly shift the position of the geometry. Yesterday, it scaled the entire project larger.
This issue is persistent; we are currently running the latest software version, but we have also encountered this exact behavior on past versions.
Thanks,
Thomas
This sounds like an issue with the hardware, potentially with the galvanometer (scan-head) board, or the controller itself.
You said “fiber laser”, but didn’t specify what kind of control card you use in either your post or your profile - If this is a JCZ-based board, try putting the stock driver back and running a couple test jobs in EZCad2. If it fails in the same ways, that would pretty clearly point at a hardware issue.
Hi,
The artwork in lightburn moves, and yesterday the artwork scaled itself up. It is a JCZ-based board.
In LightBurn?
Do you have a stuck PgUp/PgDn or arrow keys on your keyboard?
If you are in framing mode, those keys move and scale the artwork, so if your keyboard was malfunctioning, that would do it.
I’m wondering if the high frequencies from our welders are interjecting keystrokes into lightburn
Try running the job without using the framing window first. You might have to disable “Require Framing on Start” in the device settings. Then pressing start will run the job, not frame. If you enable a Job Checklist you can use that to prevent accidental starts.
I’ll try ferrite beads on the keyboard and mouse wires and see if that helps.
