Crosshairs seem off
Using stool D1 laser. The laser does not cut in the spot where the crosshairs are. It shifts the cut approximately one half inch to the left of the crosshair
You likely have the wrong pointer offset configured in Edit->Device Settings. This is typically -16 mm on the X-axis. If this is not already configured that way that implies that you did not use the .lbdev file provided by xTool to create your device.
More information on here:
User Manual for xTool D1 LightBurn Software – xTool
