Crosshatch "broken"
I figured I would give it a try again and it seems I only pick using crosshatch in versions where it borks.
Current issue is that it creates heavy scan offset (3mm+) (non-crosshatch works properly) and then does not fire the laser at all when traversing the cross (y-axis) portion of the fill.
Update: Turning off flood fill has fixed the scan offset, however still no laser activation when traversing the y-axis.
Has anyone else encountered this issue? Suggestions?
Ver 1.1.01
Ruida 6445G controller on 100W CO2
