Crosshatch on Grey scale depth maps
I have been doing some depth images using grey scale so I can use the Max and Min. power settings. I do multiple passes at differant scan angles.
Is it possible to set up a differant scan angle fore each pass.?
I would like to be able to be able to engrave an adjustable scan angle for each pass.
That’s not possible, I think. If you choose multiple passes, all passes are a copy of each other, there is no chance to change the scan angle in between.
One way to achieve that, do several duplicates of your image, enable Cute Selected Graphics and Current Position:
Set each copy to a different layer, set each layer to a different Scan Angle and to No Output:
Select first layer Image set first layer to output and run the job, set first layer to No Output at the end.
Select second layer Image set second layer to output and run the job, set second layer to No Output at the end.
And so on and so on…
I will adjust it manually after each layer is complete. That way I can adjust power settings also.
The idea was to save your current project as a Template so that you have a reference for future jobs with a bit less changes(work.
