Hi.
I’m using Hebrew text and I want to make my text with a curve.
But, when I attached it to a curve and clicking the “Apply path to text”, the text gets the curve but now its up-side down,
I will appreciate any assistance.
Thanks.
Can you post a screenshot of what’s happening?
Hi,
Thanks for your kind help.
This is a screenshot of the Lightburn screen.
The last word of the sentence should be in the place indicated by the red arrow, but the sentence is reversed and the end the sentence is up-side.
Hope this helps.
Draw the curve in the opposite direction and it will show the text oriented in the other direction.
Meaning, if you drew the line from left to right, then instead draw the line from right to left. You can see the line direction if you use the Shape Start Point tool and click on the line.
Thanks, I haven’t know about it.
Hi, still having problems with the curved text. As you can see in the drawing, I try to insert the text inside the lines. But, when I try to make it smaller or “hold” the path, some of the text disappears. I try to “pull” the text or change it using the frame but I can’t. I would appreciate ideas.
It’s not clear to me what you’re seeing. Can you take screenshots please?
