Not sure what I’m doing wrong but I have a linuxcnc setup with custom g-code so it will use Q power along with M62/M67. When I create a gcode file it outputs a file that is much larger than my lightburn file. A 400mm text ends up being 14000mm? I’ve checked the rotary and it is not on. When I use the standard linuxcnc device the output is correct (but not using Q power).
Hi @Dunnr
Could you try exporting a simple 100 × 100mm square using both the standard LinuxCNC device and your Custom GCode device, then attach both GCode files here?
Please also share screenshots of the Dimensions/Units and Custom GCode sections under Laser Tools → Device Settings.
This should help us determine whether the coordinates are being scaled incorrectly during export or interpreted differently by LinuxCNC.
Dominic - thanks for your reply, I did check 100x100mm square and it gave good results.
G0 X-100Y0
;Layer C00
G1 X-100 Y-100 M67 E0 Q20 F6000
G1 X100 Y-100 M67 E0 Q20 F6000
G1 X0 Y100 M67 E0 Q20 F6000
G1 X-100 Y0 M67 E0 Q20 F6000
;return to starting pos
G0 X100Y0
Attached is gcode for some lettering which is ~200x43mm as per snip below
I copied the code into excel and added up the x/y moves (column 1/2) and as you can see it seems to grow beyond my machine limits:
| Code | Column1 | Column2 | Column3 | X | Y |
| G1 X-146.45 Y0.74 M67 E0 Q20 F6000 | -146.45 | 0.74 | -146.45 | 0.74 | |
| G1 X11.14 Y-23.834 M67 E0 Q20 F6000 | -135.310 | -23.094 | 11.14 | -23.834 | |
| G1 X-135.31 Y-0.74 M67 E0 Q20 F6000 | -270.620 | -23.834 | -135.31 | -0.74 | |
| G1 X-0.93 Y-24.574 M67 E0 Q20 F6000 | -271.550 | -48.408 | -0.93 | -24.574 | |
| G1 X-0.443 Y-0.014 M67 E0 Q20 F6000 | -271.993 | -48.422 | -0.443 | -0.014 | |
| G1 X-0.435 Y-0.073 M67 E0 Q20 F6000 | -272.428 | -48.495 | -0.435 | -0.073 |
| G1 X0.252 Y0.356 M67 E0 Q20 F6000 | -12752.529 | -1349.542 | 0.252 | 0.356 | |
| G1 X0.313 Y0.304 M67 E0 Q20 F6000 | -12752.216 | -1349.238 | 0.313 | 0.304 | |
| G1 X0.366 Y0.242 M67 E0 Q20 F6000 | -12751.850 | -1348.996 | 0.366 | 0.242 | |
| G1 X0.412 Y0.171 M67 E0 Q20 F6000 | -12751.438 | -1348.825 | 0.412 | 0.171 | |
| G1 X0.45 Y0.091 M67 E0 Q20 F6000 | -12750.988 | -1348.734 | 0.45 | 0.091 |
Here are some snips from device settings, hopefully it is something simple that I’ve entered inproperly…
Thanks, Rob
