Hi, I’m new to handling the LigthBurn software and I’ve just installed it on a LiteMaker Ultra Violet Laser Cutter from Cloudray. I already bought the license for Galvo lasers and I’ve been doing several jobs with it but after a few hours I realized that the work area is not perfectly aligned. The problem is that when I draw a perfect square of 110x110 mm it is clear that the walls are not straight lines, rather they are curved outwards.
On the other hand, if I make the same square in the program that comes with the machine, I don’t have this problem. (ezcad2). Can anyone tell me why this is happening to me? Thank you so much
Did you import the EZCad correction file when you created the device?
