Cut Editor Settings Using No. of Passes
Been working on finding the best setting to cut 1/4 in Basswood and settled on 100 speed and 60% power with 2 passes. The program will burn each color coded areas twice before moving on to the next area which is good with the exception of the smaller areas which can be over burned. What is the best way to burn the same color tool paths completely once before executing the second pass.
You could attempt creating 2 sub-layers with the same settings. That should cut one whole sub-layer at a time.
Thank you, I knew the software had an answer and now I have some more knowledge on how to do things.
