Cut in & Cut out Feature
Is there a way to change the side of the line that the cut in and out option cuts from. Basically if I had a circle inside of a circle I would like the inner circle to be cut leading in and out from the inside (waste piece) and the outer circle to cut in and out from the outside which is the default action?
Set the angle to negative for inside, positive for outside.
OMG, I didn’t think about that. I just tried that and it works. Thank you so much for the reply. Just got this laser for cutting leather and was comparing Lightburn to RdWorks that came with it. I would rather start off with the software I want to use from the start since they don’t read each others file. Think I am going to like Lightburn better.
