Cut lightburn file in 4
hello
i have a 700x500mm machine and i want to realise a 1mx1m object (engrave and cuts), so i need to cut my file in 4 x 500mm. how to do it? i already checked “cut and print” fonction, but it doesn’t answer my need.
thanks for any help
How to divide it really depends on whether you are working with a vector or an image. If you upload your file we can better explain/show you how to divide it.
The Print & Cut function is how to register multiple cuts to each other.
What you’re looking for is the “Cut Shapes” tool:
thanks thelmut for the input
thanks its exactly what I need. So lightburn is much better than illustrator to do that…
